B&O Beovision 7-40 - Try One And See How Good They Are
21st September 2007
Buying a new television nowadays is a major investment. Spending what could be a considerable amount of cash should make you think seriously about what is essentially a major domestic investment.
The way that technology changes so quickly nowadays you would be wise to consider carefully any investment and try and ensure that it remains compliant with all possible standards.
The latest telecommunication system for broadcasting moving pictures and sound is known as Digital television (DTT) and as the name implies this relies upon the transmission and reception of digital signals as opposed to the more conventional analogue formats. Introduced in the late 1990s, this technology appealed to the television broadcasting business and consumer electronics industries as offering new financial opportunities.
With this article the aim is to take a look at what is on offer with the latest generation of Flat Screen Televisions and in this case the B&O Beovision 7-40.
The Beovision 7-40 is a 40in LCD TV and currently these TV's can be found for 7470 pounds sterling or 15000 US dollars. The screen resolution is 1366 X 768 and with regards to being HD Ready the answer is yes. The Beovision has 3 (3 RGB) scarts and the type and number of Multimedia interfaces the Beovision 7-40 uses is DVI and 1. The type of Tuner for this TV is Analogue and Digital and the Beovision is available from specialised outlets only.
So how would we rate the B&O Beovision 7-40?
First up, we would look at the picture quality and our score here would be 10 out of 10, and for the sound quality we would rate it at 10 out of 10. Taking a look at the number of relevant connections and their availability, our score would be 8 out of 10. If we take a look at the overall "featureability" our score would be 8 out of 10 and for ease of use and overall value for money we would give it, 6 out of 10 and 6 out of 10 respectively.
Finally our overall opinion would be the performance of this TV it has to be said is pretty fantastic but a similar performance can be had for a fraction of the price and therefore giving much greater value for money if you know where to look elsewhere.
With the wide range and variety of makes and models available for you to choose from it is unlikely that you will not find something to suite your taste or satisfy any budgetary constraints that you might have. The choice, as they say, is completely down to you to decide whether to stay at the forefront of what are rapidly changing technologies and fashion or to remain part of the safer but perhaps better developed mainstream. Either way we hope that by reading this short article you should have a slightly more informed view of the options available to you
With regards to the prices in this article we have tried in all cases to take an average across the industry from a number of well known web sites and so we ask you to bear this in mind and treat these prices as advisory only rather than absolutes.
Scott James writes about Flat Screen Televisions and the new generation of Plasma and Digital Televisions at Cheap Flat Screen TV and http://www.bestflatscreentv.biz
