1st March February 2012
Latest post 10-17-2008 4:40 PM by Razlaw. 18 replies.
09-22-2007 3:17 AM
- Joined on 04-01-2007
- UK
- Posts 970
Beolab 2 Dolby Digital set-up or Dolby Pro-Logic set-up?
The Lab2 instructions show to connect all 5 speakers to the TV for a Dolby Digital System but for a Dolby Pro- Logic system to connect the front speakers to the Lab2? Which is right? My TV broadcasts in Dolby Pro-Logic most of the time, but the DVD plays in Dolby Digital??? Also my Beosound 4 is connected the the TV, so again would that favour the Dolby-Pro Logic set-up? My Set-up - Avant DVD (last version) Lab 2, 8000's, 4000's
Peter
- Joined on 02-12-2007
- Posts 9,572
Re: Beolab 2 Dolby Digital set-up or Dolby Pro-Logic set-up?
I have mine attached to the TV via the sub-woofer connection. It plays when I am just using by BC2 for music and also plays when the channel I am watching is not Dolby Digital - or indeed Dolby at all.
- UK
- Posts 970
Are the low frequencies filtered by the Lab 2 before reaching an attached pair of speakers? And IMHO if all speakers and sub are connected to the TV then the front speakers do not have reduced low frequency.
Peter
- Posts 9,572
I understood the TV did that itself when you specify sub-woofer. I may be wrong.
- UK
- Posts 970
That what I would have thought but in testing it doesn't sound that way.
BarryAndrew
- Joined on 09-07-2007
- Cornwall, UK
- Posts 72
This is the point that I was trying to get at with my last message on the Beolab2 thread and my concern all along. When I am using music does the "system" (and lets face it thats what we buy even if we assemble it in stages) prevent over-bassing the process by running the beolab 2 as well as the bass on the 8000. I was hoping that the presence of one would make the others un-necessary or reduce at the minimum. I don't want to spend whatever it is just to find out that I have much too much bass (or boominess). I really do believe its a modern trend to concentrate music (mostly manufactured) on the bass and treble. These were the concerns I have when I tested the 9's. I couldn't really get a satisfactory mid-range (although it was a shop test and hardly fair given the music he was playing). My 8000's are just what I want + an extension to the bass I am not looking for the bass to take over.
Barry
BV6-26,BC2300,Beolab8000,4000,3500,2000,DVD1
PhilLondon
- Joined on 04-16-2007
- London
- Posts 2,545
It is not about the system that is used in broadcasting, it is about the system that is in your TV. If your TV has a subwoofer output... use it
- UK
- Posts 970
wtlc2zpx:It is not about the system that is used in broadcasting, it is about the system that is in your TV. If your TV has a subwoofer output... use it
yes but thats the point, if i do I get a resonating bass from the 8000's and lab2 requiring turning down the bass settings.
- UK
- Posts 970
Does anybody know the science between the too set-up options? I would hazard a guess the DD5.1 system is designed to redirect the bass from a DD5.1 source to the Beolab2 if SUBWOOFER is set to YES. But an audio system connected to the TV does not have the same effect resulting in bass to all speakers. ?? Anybody confirm?
BarryAndrew
- Cornwall, UK
- Posts 72
Thanks for coming back on this with your last two messages. I don't want a system whereby I have to change the leads every time I watch a DVD (or alternatively play music). Because the two fronts are connected to the Dolby and that recognises that music is being played (i.e. the third --tv speaker) cuts out automatically I thought that connecting the sub woofer to the tv might be controlled similiarly. On the other hand may be it isn't and is only useful for DVD's in that position. If thats the case I don't want it.
Barry
- UK
- Posts 970
Its not fact, just my opinion. I haven't tried both options to compare yet. It could be my room that requires the bass be lowered. Don't dismiss it yet on my account, please.   For movies I love it 10/10, however with music I am tweaking with the BASS.
BarryAndrew
- Cornwall, UK
- Posts 72
If I put a non B&O active sub onto the sub socket on the dolby digital with a powerlink to RCA connection will things work satisfactorily,
Barry
kallasr
- Joined on 04-19-2007
- Willich, NRW, Germany
- Posts 1,077
Yes, they will. Be sure to buy one with adjustable take over freqency (see other threads in this forum on this subject). Ralf
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
BarryAndrew
- Cornwall, UK
- Posts 72
I am reviving this thread because it strikes me that we have a number of unsatisfactory sub-woofer questions flying around at the moment. This thread still leaves unanswered the question of the sub going through the DTS as compared with the powerlink socket of the speaker. From this thread I understand that the latter replaces the bass on the speakers and thus is better for music whereas the former adds to the bass on the speakers and is better for DVD. Do we need two sub woofers -- no surely not so what is going on. There is more than one person on this site wanting to add a non-b&o sub. Are we making a mountain out of a molehill?
Barry
- UK
- Posts 970
If I listen to music from the BS4 as per fig. A then bass is directed to both BL8000 & BL2 = too much bass, not nice
if I connect BL2 to my BS4 and the BL800's to the BL2 then the BL2 handles all the bass. = bass is nice, sounds nice
so would figure B be recommended if a Beosound (no speakers connected directly to it) was connected to a Beovision ?
Razlaw
- Joined on 04-24-2007
- Illinois
- Posts 1,770
I share your question. We previously had Beolab 9s connected to an Avant and a Velodyne sub connected directly to the Avant. It seemed to me that turning the sub away directed too much bass away from the 9s. I only wanted the sub to play the very lowest frequencies that the 9 could not reach. I finallyturned the sub off because I wanted all bass to go to the 9s even if I was missing the very lowest frequencies. We now have the 9s and sub connected to a BV7 MKIII and so far I do not seem to notice the same problem.
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
Page 1 of 1 (19 items)
