Hallo,
I think there are some things mixed in the explanation of the Beoport.
- The audio sources from the main source (Beovision) can be controlled with the Beoport. This can be done because it is no multiroom system. Only one source and if you swith the radio channel or cd it is also done in the main room. The radio or cd sound can only be heard from the Beoport if there are the loudspeakers connected to. The sound is not going into the PC. It ends at the Beoport. I read that there is a hidden minijack connector and one can connect the PC loudspeakers there but I am not sure about this. I haven't tried this up to now.
- The video sources are only distributed with the system modulator. You need a tv cable to your PC and a tv card inside. I have experienced when you don't have a tv card you can't switch to tv/dvd/... the Beoport is switching back to PC.
- For this sources you control on your PC the sources for your PC. But when e.g. the CD is on in the main room it has also effects to the main room.
- N.MUSIC/N.RADIO: First you have to set the settings right at the PC. For N.MUSIC you have to scan the directories for your music. After this is done you can control these sources on your PC and with supported devices (Beosound 3000 / Beosound 3200 / ...) in the main room. And if you hear N.MUSIC in the main room (and at the PC) you can control the N.MUSIC for both locations.
Frank
