Latest post 09-19-2007 10:08 AM by beaker. 2 replies.
Page 1 of 1 (3 items)
  • 09-19-2007 9:01 AM
    Beomaster 5500 Problem
    I have a Beosystem 5500 of which the Beomaster has developed a fault. It works for a few minutes then cuts out or goes really tinny. It also clicks when it cuts out. This happens even with no speakers connected so it cant be a cable issue. I am hoping its something simple. Does anyone know of someone in the South East (of the UK!) that could give it a service or would it be cheaper just to get rid and buy another. I would rather repair it though but obviously what ever is the cheapest will be done.
    Many thanks.
  • 09-19-2007 9:19 AM In reply to
    Re: Beomaster 5500 Problem
    Suggest you contact Tim Jarman at www.beocentral.com and I'm sure he will fix it for you.
    Regards Graham
  • 09-19-2007 10:08 AM In reply to
    Many thanks,  will do
