Latest post 09-21-2007 10:59 AM by 850volan. 4 replies.
Page 1 of 1 (5 items)
  • 09-17-2007 2:02 PM
    Can i connect Beocenter 2300 to Beolab 3500 (link speaker) ? and how?
    Hi!  I have BC2300 and my friend wants to sell me Beolab 3500 link speaker,just wonder if they are compatible cos my BC2300 doesn't hav e the socket for connection from the BL3500. Some said i have to use converter. Which one should i use? Please lighten me up,thanks
    Filed under:
  • 09-17-2007 2:09 PM In reply to
    • Ulf
    • Top 100 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 665
    Re: Can i connect Beocenter 2300 to Beolab 3500 (link speaker) ? and how?
    You can use an 1611 Converter
    Ulf
  • 09-17-2007 2:25 PM In reply to
    • matheyl
    • Top 500 Contributor
    • Joined on 04-18-2007
    • French Alps
    • Posts 228
    Good eve,
    You should be able to connect a BC2300 to a BL 3500, pluging a Beolink Converter to the AUX and POWERLINK of the 2300 on one end, and a masterlink cable to the BL3500 on the other.
    In that configuration, I'm not sure that you can connect other speakers to the BC2300, as the Powerlink connexions are already used for the BL3500....
    You will find the Beolink converter's User guide in the manual's section of Beoworld.
    Hope that did help,
    Cheers, Laurent.
    Avant 28 DVD, BC2, 2300, BL2500, 8000, to name a few...
  • 09-17-2007 2:43 PM In reply to
    Connect the beolink converter between the AUX on the 2300 and ML on the 3500. Worked a treat on the one I tried. Both powerlinks on the 2300 are empty and can be used for other speakers.
    Regards Graham
  • 09-21-2007 10:59 AM In reply to
    HI! again
     Thanks for the prompt reply but i have another question. If i connect the Beolab 3500 link speaker through beolink converter to my Beocenter 2300 via AUX ,i still need to connect other AUX input like ipod or my computer to my BC2300,so how can i do that cos there is only one AUX input on my BC2300. Thank you.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
