Latest post 09-18-2007 7:18 AM by Alex Barnett. 3 replies.
Page 1 of 1 (4 items)
  • 09-17-2007 7:40 AM
    Beolink 7000 setup
    Duh... does anybody know how to get into the system setup on the Beolink 7000? I'd like to set mine to 1-way control for the time being, as I've just sold my Beovision MX5500 and there's only my Beocentre 8500 to use it with now! Thanks - Alex.
    ________________________________________ Beowulf - the Original music aficionado...?
  • 09-17-2007 7:42 AM In reply to
    Re: Beolink 7000 setup
    PANEL, then SETUP, then SYSTEM, then COMPONENTS
  • 09-17-2007 8:15 AM In reply to
    The BL7000 essentially sets itself up. If you change your system, go into the Panel/Setup/Systems/Components section as detailed above and remove all the components. Save this and then going into exactly the same place, add those components you have. The Beolink 7000 sends out a test signal and if it gets a response, the component is stored as 2 way, and if it gets no response, one way. Clever these Danes!
  • 09-18-2007 7:18 AM In reply to
    That's great, thanks guys - D'you know, I didn't realise "Display" and "system" were two separate buttons... they're so close together I thought it referred to "Display system".... Unsure  All sorted now, the Beocentre is back under control of the Uberkommander.
