Latest post 09-16-2007 8:24 AM by Beoik. 2 replies.
Page 1 of 1 (3 items)
  • 09-15-2007 6:35 PM
    Dual Beolink eyes
    Basically I have a Beolink Passive that I am using for outdoor speakers. I have a pair in the front and and pair in the back, basically I put a switch in to switch between the two pairs.
     The beolink eye is in a weather proof box mounted under the eaves of the roof in the front yard. I only have the IR wired, I am not using the buttons in front because it is mount high under the eaves and can't reach it. OK, so I have read that I can tie two IR Beo eye pucks in sequence, but since I am only using the IR I just need a IR detector. Does anyone have a schematics on how I wire a 455khz infrared red detector to a beolink passive? i.e I want to make a down and dirty beolink eye without the need for the buttons, it just needs to send the ir to the passive.
    Eric
  • 09-16-2007 5:30 AM In reply to
    Re: Dual Beolink eyes
    Hi
    I think you should look for two MCL Extra Speaker Kits, that will do it the B&O way Smile
  • 09-16-2007 8:24 AM In reply to
    solder a wire to the original ir receiver inside the existing ir receiver unit and connect that to another receiver on the backside of your house.
    You just have to drill a little hole somewhere to hide the receiver
