My setup is as follows: Beosystem 1 with BS9000 linked together in the same room, then I have a beolink passive setup for outdoor speakers.
I used to be able to listen to my tv outside, but now it will only play radio, cd player outside. Could someone please advise what the correct option setting would be for a beolink active eye mounted outside. And do I set these options at the eye on on the main system?
One other question is, can I some how control the output of the beolink passive inside at the BS9000, i.e. is there a way to press link and then something on the remote to do this? So lets say I am outside (beolink passive) and turn up the volume then I go inside and want to turn down the volume, instead of going outside can I press LINK on the beo4 and something to change the volume at the BS9000.
Eric
