Thanks guys. I took the platter off, moved the arm in, and it traversed all the way over. Also, there is a lamp right below the arm, that moves when the arm is moved, and that is 'on'.
 You can see the stylus deflecting to the left, before jumping back to the center of the cartridge. So it is the arm that is not moving.
 I also tried increasing the tracking force, and also using 2 lps, in case the arm was not being lowered enough. No difference.
Any other ideas? Thanks, Samir.
