Latest post 09-13-2007 11:51 AM by BarryAndrew. 2 replies.
Page 1 of 1 (3 items)
  • 09-12-2007 3:32 PM
    Beolink converters
    Can I ask the question in a different way then? (see advice on set up).
    If I put a Beolink video in between my BV6-26 and my MX4000 can I take my ordinary Beolink converter out of the system or does it need to stay in to take the Aux based audio products? Signature explains the product mix.
    Thanks in advance
    Barry BV6-26,BC2300,Beolab8000,4000,3500,2000,DVD1
  • 09-12-2007 3:58 PM In reply to
    Re: Beolink converters
    I take it that you are connecting the 2300 to the BV6 and using the MX in a link room. The problem is that you need the 2300 to speak to the ML system and so I think you need a 1611 to allow this to happen. So I think it needs to stay!
  • 09-13-2007 11:51 AM In reply to
    Spot on Peter and many thanks for your help. I just can't see the solution immediately. The 2300 and the BV6-26 are in the same room and I want to put the MX4000 where the 3500 currently is. I will sit down and think about it and I am sure that it just needs a bit more spark!
    Thanks again
