Latest post 04-19-2007 1:46 PM by Sudla. 4 replies.
Page 1 of 1 (5 items)
  • 04-19-2007 2:59 AM
    • Sudla
    • Not Ranked
    • Joined on 04-18-2007
    • Posts 14
    BV3-32 and Topfield HDD receiver
    Hi@all,
    I have connected the receiver via RGB Scart and koxial digital input. Now when the receiver starts up for records automatically, the BV starts as well as the receiver. Is there a way to deactivate this?
    Many thanks in advance!
  • 04-19-2007 4:39 AM In reply to
    • SKApretto71
    • Not Ranked
    • Joined on 04-19-2007
    • Europe - Italy - Tuscany - Fucecchio
    • Posts 66
    Re: BV3-32 and Topfield HDD receiver
    I add the same issue with my Pioneer DVR. I had to switch some settings on the Pioneer to not let signals go over the SCART when recording (it's a switch the Pioneer has), and this solved the problem.
    May be a similar option is even on your receiver.
    Raffaele "SKApretto n.71" Sgherri
    I like Chrome and spread it!
  • 04-19-2007 6:54 AM In reply to
    • Sudla
    • Not Ranked
    • Posts 14
    thanks.
    Does anybody know which scart connector on the backside supports RGB in combination with digital sound input of the DTS module?
    Or does this depend on the software settings under the menue-->connections-->Decoder, V.Tape or DVD, etc.?
  • 04-19-2007 11:02 AM In reply to
    About the digital inputs.
    The first input goes with the AV scart and the second digital one goes with the Decoder scart.
    How did you solve the connection between the digital output from the topfield and the input from the BV-3?
    Both the Vtape and AV scart supports RGB.
  • 04-19-2007 1:46 PM In reply to
    • Sudla
    • Not Ranked
    • Posts 14
    There exists a powered adapter to convert Toslink into coaxial signal. Have a look on Ebay!
