Latest post 10-09-2007 9:54 AM by Dave. 3 replies.
Page 1 of 1 (4 items)
  • 09-11-2007 6:01 AM
    • nik
    • Not Ranked
    • Joined on 04-19-2007
    • Pescara, Italy
    • Posts 2
    Beosound2 & MacIntel (OSX 10.4.9)
    I've downloaded the sw to install the Beosound2 in my new MacIntel but the install tool do not works! A message tell me to change the Beos2 to mac mode: my Beos2 do is in mac mode!
    The firmawe is updated via PC and works fine with XP and old OS9 classic.
    In OSX 10.4.9 intel I can't manage to run the application to see the device on iTunes (7.3)
    Anybody may help me?
    Tanks!
    nikEmbarrassed
  • 09-27-2007 10:33 AM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    Re: Beosound2 & MacIntel (OSX 10.4.9)
    Sorry to inform you, but the beosound 2 isn't compatible with intel mac. It just doesn't work! Sad Very annoying isn't it! The only thing you can do is drag and drop (From folder to folder. Forget about the simplicity of iTunes, because it isn't compatible).
    I'm used to dragging and drooping now however, and it is fast thanks to a USB 2.0 card reader.
  • 10-03-2007 5:27 PM In reply to
    It is now!! New software update now on the B&O site!!
  • 10-09-2007 9:54 AM In reply to
    • Dave
    • Posts 2,328
    Surprise
    ARGH!! Finally.
