To all you Beonuts,
My signature provides the list of equipment that I have to deal with and the only factor I have to add is that the MX4000 is connected to the main system but because there is no beolink converter only analogue TV and sound (including CD & Radio) is transmitted. I want to take advantage of some decorating to move my bits around and I am sure that I don't need much but need it confirming.
I think the essence of my question is;
If I change my existing audio converter (which as you well know allows the mix of AUX with ML) with a beolink Video connector can the BC2300 be placed anywhere on that system where I can get an AUX cable into it? I suppose I could put that another way. If I go from ML on the BV6-26 to the video converter can I bring two AUX cables out of the converter -- one to go to the MX4000 and one to go to the BC2300?
I think I can but am not sure how the video converter works.
Barry
BV6-26,BC2300,Beolab8000,4000,3500,2000,DVD1
