Latest post 09-11-2007 4:26 AM by Bouncer. 2 replies.
Page 1 of 1 (3 items)
  • 09-10-2007 10:09 PM
    Problem with BeoCom 6000
    Hi there,
    I have been moving a lot over the past two years so I havent been using my BeoCom 6000.  Now that I have finally settled down and I want to use my Beocom.  The rechargable battery is gone which is understndable, but I have found that I am having problem with my keypad.  I can still receive and make phone calls but I cannot get into the Menu.  Could this be a bad contact with the keypad after 2 years of not using it and can that be fixed easily?
    Thanks.
    Bouncer
  • 09-11-2007 3:23 AM In reply to
    Re: Problem with BeoCom 6000
    Common fault with the "dot" button apparently. One of mine went the same way. Your dealer can get a complete front panel for  around £15 which cured my problem.
    Regards Graham
  • 09-11-2007 4:26 AM In reply to
    Hi joey,
    Yes, it was the dot button. The dealer just got back to me, around 30 euro to get it changed. I already paid 25 euro for the battery Sad. Hope it will last longer this time.
