1st March February 2012
09-10-2007 1:36 PM
blackbird160
- Joined on 04-23-2007
- Posts 22
Can Beo5 control non B & O equipment?
I visited my local dealer today and was pleased to see that he had a Beo5. It looks and feels great, however he told me that it will only control B & O equipment and some set top boxes. I thought that others on the forum have said that it will control other equipment. So who's right?
matheyl
- Joined on 04-18-2007
- French Alps
- Posts 228
Re: Can Beo5 control non B & O equipment?
Beo5 will be able to control non-B&O products if connected to P.U.C. equipped B&O tvs. If I understood correctly... Cheers, Laurent.
Avant 28 DVD, BC2, 2300, BL2500, 8000, to name a few...
misled
- Joined on 04-25-2007
- Switzerland
- Posts 66
BVision10-46,BLab11,BSound5,BMaster5,BLab8000,BLab6000,BLab2500,BCom5,BCom6000,BeoTime,BeoPort,Beo4,Beo5
The Stig - ver. 1.7
- Joined on 06-20-2007
- Posts 898
Yes only B&O. It can control some curtains and projector screens but i don't know if it's the remote thats sends the Ir or if it's the beoliving box (don't know the real name for this system modul)!
The Stig - ver. 1.7
- Posts 898
misled: what is p.u.c?????
It's the same as a settop box (stb) controller just that it also can control DVD and VCR a STB controller makes it possible to control a sat receiver by Beo4 remote
Gerd
- Joined on 04-20-2007
- Germany
- Posts 523
Peripheral Unit Controller
Keith Saunders
- Joined on 04-16-2007
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
The Beo5 has three IR transmitting diodes for controlling B&O and other products. Clearly B&O wish to limit "the other products" to vendors it has approved, meaning they have a business partnership relationship with them, for example Lutron for lights It will control all STB's which are defined in the current STB controller table (PUC is the new B&O name for STB) So, in answer to your real question "so who's right" I guess they both are.. The device itself can control non B&O products, but B&O almost certainly want to limit which ones they will allow you to use.
- Joined on 04-01-2007
- UK
- Posts 970
Keith Saunders: for example Lutron for lights
I have some B&Q Varilight dimmers fitted, are they on the list by any chance?
beo4me
- Joined on 04-17-2007
- Posts 175
Keith Saunders: The Beo5 has three IR transmitting diodes for controlling B&O and other products. Clearly B&O wish to limit "the other products" to vendors it has approved, meaning they have a business partnership relationship with them, for example Lutron for lights It will control all STB's which are defined in the current STB controller table (PUC is the new B&O name for STB) So, in answer to your real question "so who's right" I guess they both are.. The device itself can control non B&O products, but B&O almost certainly want to limit which ones they will allow you to use.
In the specs on the B&O page it says IR for 455 kHz and 2080 kHz on Beo5. As most of the other brands TV's, DVD-Player, etc. are in the range of 30-100 kHz how could the Beo5 control any of these? Frank
PhilLondon
- London
- Posts 2,545
Hi, Here is where the confusion may come from. Let's say you have a sky box (a stb). With the Beo 5, it is still controled by the PUC or STB-C from the TV itself. The difference, is that you can configure the Beo5 and tell it that behind DTV there is a sky box. What it then does is display on the screen buttons with names that correspond to the Sky box features. For example, Instead of Go 1 for Info, you'll have an "Info" button on the Beo 5. That said, it will still send a Go-1 signal, which will be interpreted by the TV and the PUC will convert it into the "Info" code for the Sky Box. Beo5 will be able to control other devices, not through the PUC but it does seem reserved to "environment" devices, such as light and curtains, etc... p.
The Stig - ver. 1.7
- Posts 898
wtlc2zpx: Hi, Here is where the confusion may come from. Let's say you have a sky box (a stb). With the Beo 5, it is still controled by the PUC or STB-C from the TV itself. The difference, is that you can configure the Beo5 and tell it that behind DTV there is a sky box. What it then does is display on the screen buttons with names that correspond to the Sky box features. For example, Instead of Go 1 for Info, you'll have an "Info" button on the Beo 5. That said, it will still send a Go-1 signal, which will be interpreted by the TV and the PUC will convert it into the "Info" code for the Sky Box. Beo5 will be able to control other devices, not through the PUC but it does seem reserved to "environment" devices, such as light and curtains, etc... p.
Thats spot on
Page 1 of 1 (11 items)
