Latest post 09-09-2007 1:24 PM by joeyboygolf. 5 replies.
Page 1 of 1 (6 items)
  • 09-08-2007 10:15 AM
    • twadle
    • Not Ranked
    • Joined on 04-16-2007
    • Berkshire, UK
    • Posts 15
    9500 sound loss
    I have a Beocentre 9500 which has no sound unless it is played a the maximum level, and then it is faint. I have tried plugging in a set of headphones with the same result.
    Does anyone have any advice/help. I know which end of a soldering iron to hold and can, unlike my cocker spaniel, follow simple commands!
    All help/advice is greatly appreciated.
    Thanks,
    twadle
    Thanks, Phil
  • 09-08-2007 3:52 PM In reply to
    Re: 9500 sound loss
    Is the low sound level apparent with all sources?
    Regards Graham
  • 09-08-2007 5:54 PM In reply to
    • twadle
    • Not Ranked
    • Berkshire, UK
    • Posts 15
    Re: 9500 sound loss
    Hi Graham,
    Yes.
    Phil
    Thanks, Phil
  • 09-09-2007 2:24 AM In reply to
    Re: 9500 sound loss
    Hi Phil
    What happens when you plug speakers into the Spk2 sockets?
    Regards Graham
  • 09-09-2007 3:55 AM In reply to
    • twadle
    • Not Ranked
    • Berkshire, UK
    • Posts 15
    Re: 9500 sound loss
    Hi Graham,
    I get exactly the same response from all speaker sockets, including the link sockets. I have also tried several sets of speakers both passive and active with the same result.
    Thanks,
    Phil
    Thanks, Phil
  • 09-09-2007 1:24 PM In reply to
    Re: 9500 sound loss
    I suggest that you contact Tim Jarman at www.beocentral.com who will probably be able to fix it if you can get it to him.
    Regards Graham
