In the past it was uneconomical to use high bit rate mp3's on sd cards as the amount of songs was so limited. Now with 1 and 2 gig cards becoming extremely cheap i have started to use 256kbps for my mp3's. This is great for listening at home through my loudspeakers however, the same files played on my BS2 (with A8's) seem to distort or clip at only moderate volumes.
Does anyone know if there is some sound processing that goes on inside BS2 that would be causing this. There is no problem on bit rates at 192 or below.
cheers for any thoughts on this.
