Latest post 09-05-2007 3:49 PM by Rasmus. 5 replies.
Page 1 of 1 (6 items)
  • 09-05-2007 9:23 AM
    • Rasmus
    • Not Ranked
    • Joined on 04-24-2007
    • Aalborg, Denmark
    • Posts 9
    MX 7000 PIP module
    I have a MX 7000, type: 8700 which I would like to have a PIP module installed in. Can someone please explain which PIP module i should aquire and where I can buy one?
    Someone have offered me a PIP module from a LX 5500 - can this be used? He says that the servicemanual for this module says: Type 4120 (LX) og 4121 (MX) and on the PCB: 80073350 and 44900095.
     Hope to hear from you experts... Geeked
    Best regards,
    Rasmus
    Best regards, Rasmus M. Jensen
  • 09-05-2007 11:56 AM In reply to
    Re: MX 7000 PIP module
    The module for the LX5500 will not fit. The one you need looks like a triangle... the 5500 is a square and internally complete different.
  • 09-05-2007 2:54 PM In reply to
    • Rasmus
    • Not Ranked
    • Aalborg, Denmark
    • Posts 9
    ok... thank you for your answer... do you have any idea where to find such a module and do I need anything else to get PIP working? I'm thinking - do I need to change firmware or anything like that?
     Can someone please comment on this PIP module: http://my.qxl.dk/accdb/viewItem.asp?IDI=515114182
    which models is it for?
  • 09-05-2007 3:00 PM In reply to
    You need Firmware 1.x.
    Firmware 2.0 does not support the pip module. At least the series firmware 2.0 does not work with it, i had the same problem and had to downgrade to 1.1.
    I think the shown module is for Avant or later models.
  • 09-05-2007 3:46 PM In reply to
    • Rasmus
    • Not Ranked
    • Aalborg, Denmark
    • Posts 9
    ehh... where can I see the firmware version.
    on the backside of my MX 7000 it says: "S.W. 4.7" - and I can see it has been upgraded from ver. 4.3
    but is it not the firmware version?
  • 09-05-2007 3:49 PM In reply to
    • Rasmus
    • Not Ranked
    • Aalborg, Denmark
    • Posts 9
    Die_Bogener:
     can you reweal further information from this:
    "A6143049 VER C.
    8006608
    MO. 62010220 42"
