        1st March February 2012
								        09-05-2007 9:18 AM
									        Kim.t
								                - Joined on 04-17-2007
								                - Posts 18
										    Beocom 6000 - 3 on the line
										    Is it posible to use 2 handset at the same time - to talk to the same person ? I have the PSTN base - not the ISDN
									    BM7000,CD7000, MX4000, VX7000,2 BL5000, BL1000, 2 CX50, 2 Beocom 6000, Beocom 2500, Beocom 1600
									        Keith Saunders
								                - Joined on 04-16-2007
								                - Technical Advisor, Little Ann, Hampshire, UK
								                - Posts 3,810
										    Re: Beocom 6000 - 3 on the line
										    Yes it is, subject to software version etc. What version handsets do you have ? Mark I has DOT at the 9 o'clock position on the centre dial and Mark II has the word INT
									        Keith Saunders
								                - Posts 3,810
										    Assuming you have a Mark II Beocom 6000 you can have a conference call as follows:- During an external call, you can call another handset in your system to establish a conference call. If one participant hangs up, the call continues with those handsets remaining on the call. Whilst you are connected to your external caller press INT then turn the dial for the handset you wish to join the call then press the PHONE key and when the internal phone is answered turn the dial until you see CONFERENCE? and then press OK (centre of dial) Two internal phones and the external caller are now connected to the same line and can speak and hear each other.
									        Kim.t
								                - Posts 18
										    The problem is that I don't wan't to push to call to another handset. If I answer the phone in my office with my Beocom 2500 I want to be able to listen/join the call on a Beocom 6000
									        Christian
								                - Copenhagen, Denmark
								                - Posts 626
										    That should quite simple. Just answer the call on one of the phones, and then pick the other one up.
									    Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
Addicted? Oh no.... ;)
									        Keith Saunders
								                - Posts 3,810
										    There is a little known facility on the Mark II Beocom 6000's named "Call break in". You can establish an internal conference call  by "breaking in" on a call in progress, however this should only possible if you use a handset with the Beoline base. I have never tried the "break in" facility with an analogue phone on the same line, but you could try it. To use the "Call break in" facility, first establish a call using your from your Beocom 2500, then on your Beocom 6000 it should show on the display "Line is Busy", then press the HANDSET key on the Beocom 6000 followed by OK (centre button of the dial) and you have broken into the call. Well, you have for certain if you have a Beoline with Beocom 6000 and/or Beocom 2, I would be interested to note if it works with an analogue phone..
									        Keith Saunders
								                - Posts 3,810
										    Christian, You would be correct, if both phones were analogue, but we have here one analogue and one Beoline (DECT) and he wishes to join the call from the Beocom 6000 not the Beocom 2500.
									        Kim.t
								                - Posts 18
										    Christian is actually right - there is no problem if there is only 1 DECT phone inwolved. If I pick up the call with my beocom 2500 I can join the call on my beocom6000 by just pressing the "phone" button. My handset are mark I - with the DOT button
        Page 1 of 1 (9 items)
