In the old forum there was a thread regarding Last.fm and the possibility to get it to run with BeoPlayer. Earlier it has been mentioned that BeoPlayer makes use of Windows Media Player when playing mp3 files and likely that it does. But Last.fm software doesn't currently work with BeoPlayer and would great to figure out what's needed to get it to work. The source code is available from Last.fm to create an updated plugin to get it to work; question is just if there is info enough about the API to BeoPlayer.
Ideas / Suggestions?
