Just found a bunch of vintage B&O components:
BeoGram 2000
BeoMaster 3300
BeoMaster 2000
BeoCord 2000
BeoCord 3000
BeoGram CD3300
We tested the BeoMaster 3300 with the CD and it sounds fabulous. Tried hooking up the BeoGram 3404 (that we already had) to the BeoMaster 3300 and the tone arm goes out and over the album, then goes back. Over and over. Then it sped up! The needle never lowered, and the only way to make it stop was to unplug it. This has never happened before - the 3404 is used almost daily. Are these 2 components imcompatible? Or has something suddenly happened to our old turntable? The BeoGram 2000 works fine.
Also, the BeoCords light up, but neither one will play a cassette - is there something we are missing there?
Thanks so much!
Kara
