Latest post 09-03-2007 4:39 AM by Keith Saunders. 3 replies.
Page 1 of 1 (4 items)
  • 09-02-2007 4:50 PM
    28" Avant Screen Fault
    Hello there,
    I'm having a problem with my electronic curtain on my 28" Avant 100HZ.
    In all formats, other than 16:9, you can see a thin vertical greenish coloured line going all the way down the left side of the edge of the black curtain.
    When the image is in 16:9 ration the line does not appear. It only seems to be on the actual curtain.
    Does anybody have an idea of how to remove the annoying line?
    Filed under:
  • 09-02-2007 5:05 PM In reply to
    Re: 28" Avant Screen Fault
    Welcome to beoworld.
    the problem properly lies in your picture tube. it's possible to bay a little time by adjusting the G2 voltsh but it's best to get a technician to do this..
  • 09-03-2007 4:18 AM In reply to
    Cheers for the advice.
    So do you think the tube is on its way out?
  • 09-03-2007 4:39 AM In reply to
    The tube is on its way out for sure, unfortunately quite a common fault on early AVANT's
    Regards Keith....
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
