Hi people!
I have a BeoSound 9000 bought new in Sweden in June 1999. When I listen to CDs on it, the sound sometimes gets cut for a second (as if I had pressed the mute button), and then the music resumes exactly where it had stopped. It happens at random moments on basically all my CDs, so it is not due to some specific old and/or scratched CD. I have tried to clean the laser lens with a special cleaning CD, but to no avail... It is quite annoying.
By the way, when I listen to CDs on my DVD1, then there is no problem, but that's hardly a solution. (Maybe I should mention that my BeoSound 9000 is connected via a PowerLink cable to a Beovision 3 home cinema system - all loudspeakers are B&O of course).
Any idea about what could cause this problem? Many thanks in advance for your tips/ideas.
Vantage
