Hi Martin and other interested guys,
The caps I've used are shown above and are from Audyn, type MKP-QS.
The salesman, who also build's speakers was convinced that you can here the difference between the Audyn and other regular types.
I also replaced the 3,9uF cap (C5) in the tweeter section. B&O used already a MKT type, but then again, caps can lose their function and probably won't work as they should do. This is something you already showed us in other topics about capacitors which where leaking aleady.
First I started to replace the 2,2uF cap with a 4,7 uF as you suggested. But as I did some studying on the schematic diagram, I replaced it with the original value of 2,2uF from Audyn.
As it appears, the high pass tweeter section is a 4th order filter, and it is more delicate than a 2rd or 3rd. So changing the value from 2,2 uF to 4,7 or 5,6uF will affect the crossover frequency. The larger the value, the lower the crossover-frequency. And at that point it didn't feel right, because by lowering the crossover-frequency you are entering the terrain from the midrange section.
So I've choosen to maintain the original values and not to shortcut the resistors. My penta's are connected through powerlink and are supplied with 3 stage swith for the bass section. So I've set it to the lowest position.
Shortcutting the resistors means basically "boosting" the mid and high range compared to the bass range.
My idea about the filters is that they are specially designed in combination with the speakers units,
As I was curious about the diffrence between the modified speaker and the old one, I made a cd-r with the help from Adobe Audition.
I took some some favourite tracks I know well and changed them with Adobe to mono.
So this was the way to use your balance from the stereo knowing that the left and right chanel have the same audiosignal.
By using your balancefunction you can hear very easy the difference. And there is!!
I even invited my old man to come over to hear the diffrence.
I didn't mentioned which one was modified, but my dad could hear the difference within a second!
He also ownes a pair of penta's , so he's thinking about modifiing it also.
If your using the original tracks from the cd's then your ears are like a magnet to the modified penta.
So, I did modify both filters in each speaker.
But there is more.
Now I'm replacing the condensators and the IC2 in the amplifier and the wires which are used.
I also bought the Wima (red) caps and the Opa 2134 ic and changed the original wire to 4 mm2 in the amplifier.
At the speakerside I replaced the wires from the bass units to 2,5 mm2 and soldered them directly on the bass units.
I've changed the supplying wires from both filters to 2,5 mm2 and attached them directly to black bottom panel.
So the bass section will interfere the midrange less by suppling them seperatly.
Bulgarien already mentioned this earlier on the old forum, and he is right about that.
An 200 RMS amplifier connected through a 1-1,5 mm2 wire [:'(]
After this modification I again used the cd-r to hear the difference. And again you can hear it. Man I'm proud of the progress I've made !
So I only have to modify the other speaker.
I know for certain that men really can enjoy the music again.
I even dare to say that the can stand the BL9 easily. It feels likes the artist is really performing in your livingroom with the clarity from the mid and high range and the direct punch from the bass section.
So I would like to say, spend some money on the pentas, they are worth it
