Extract from my FAQ on the subject
When I purchased my LCS9000, I was told it could only be used with MCL (Master Control Link), is this true ?
No, All units from day one shipment had both MCL and Master Link, however on the LCS9000’s the masterlink socket was covered with a black plug which made it appear that it only had MCL.
To use the MasterLink you need to remove the black plug and enable it via a service menu command. To get into the service menu to switch between ML & MCL press MENU then MENU then 0 then 2 then PLAY, then use the up arrow to switch, then store
