Latest post 08-31-2007 8:21 AM by Medogsfat. 6 replies.
Page 1 of 1 (7 items)
  • 08-29-2007 9:44 PM
    Beocenter 2200
    An acquaintance of mine recently gave me a Beocenter 2200.  I'm trying to assess the condition other than by visual inspection and would like to connect 2 speakers, but it appears that the connection for the Beocenter may be a proprietary type of connector.  Can anyone help?
  • 08-30-2007 3:47 AM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: Beocenter 2200
    We have an FAQ on site that tells you what you need! Big Smile
    FAQ
    Lee
    Smile
  • 08-30-2007 7:28 AM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Beocenter 2200
    Not a bad little music center but will probably need the belts replacing on the cassette deck soon if not now. Not a difficult task for anyone with decent DIY skills.
    Other thing to be careful of is the cartridge/stylus. If it is in good condition then leave it where it is - don't be tempted to remove it for cleaning unless absolutely necessary as doing this can cause the 4 pins to lose contact with the inner coils and render it useless. A very expensive item to replace.
    The BC2200 can be improved no end by using the right speakers and you can also connect a CD player via the tape 2 socket which is on the front lower edge.
    Chris.
  • 08-30-2007 8:00 AM In reply to
    • Dillen
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beocenter 2200
    The speaker plugs needed are standard 2-pin DIN.
    Actually the only industry standard speaker plug ever produced.
  • 08-30-2007 9:23 AM In reply to
    Re: Beocenter 2200
    Medogsfat, thank you for the information, can you expand on "by using the right speakers"?  Is there a preference for 4 or 8 Ohm?  Or would you recommend B&O speakers vs. any otehr 4 or 8 Ohm?
  • 08-30-2007 10:53 AM In reply to
    • Dillen
    • Posts 5,008
    Re: Beocenter 2200
    What Chris means, I think, is that many Beocenter 2200's
    were originally sold together with some X-type speakers and
    it would easily pull larger and much better speakers and at
    the same time give much better results.
    It's a japanese hybrid (IC) amplifier construction so, soundwise,
    probably can't be compared directly to the older
    B&O DC-coupled ones but given good speakers it will
    perform quite well and does actually pack a fairly good punch.
    4 or 8 ohms is not really that important as long as you only have one pair of speakers connected.
  • 08-31-2007 8:21 AM In reply to
    • Medogsfat
    • Posts 4,045
    Re: Beocenter 2200
    Thanks Martin, that's exactly what I meant.
    I once owned a BC2200 which came with X35 speakers which were OK but no more. When I connected some B&O redline RL60.2's the sound improved 10 fold. They were also a much better cosmetic match IMO and are relatively cheap to obtain..
    You don't necessarily need to use B&O speakers as there are lots of other great makes out there but I can only comment from my own experience.
    EDIT- nearly forgot the important bit!Surprise. When you are wiring up the 2 pin DIN speaker plugs the positive side of the wire should be connected to the small round pole and the negative side to the flat spade.
    Chris.
