Latest post 08-22-2008 7:19 AM by skd. 8 replies.
Page 1 of 1 (9 items)
  • 08-29-2007 12:17 PM
    • pgerell
    • Not Ranked
    • Joined on 05-24-2007
    • Stockholm
    • Posts 77
    MCL cable/connectors for Beomaster 5500
    I want to use a Beolab 3500 as a link room speaker.
    Where do I find a cable or connectors to connect it to the beomaster 5500?
    I think it should be something like two speaker plugs with an extra pin each.
    Best regards Peter
  • 08-29-2007 12:26 PM In reply to
    Re: MCL cable/connectors for Beomaster 5500
    You can connect your MCL enabled Beolab 3500 to your Beomaster 5500 using the cables shown below.
    They are two speaker type plugs each with an extra pin and on the other end a din plug which goes into the Beolab 3500
    MCL Cable
    Regards Keith....
  • 08-29-2007 5:33 PM In reply to
    • pgerell
    • Not Ranked
    • Stockholm
    • Posts 77
    Thank You!
    Is that B&O part numbers? Does that mean that I can still order them from my dealer?
    What site did you get the picture from? An internal B&O site?
     /Peter
  • 08-30-2007 2:10 AM In reply to
    The numbers quoted are B&O part numbers and they can still be obtained through B&O dealers
    Regards Keith....
  • 08-30-2007 6:38 AM In reply to
    • pgerell
    • Not Ranked
    • Stockholm
    • Posts 77
    Thank You
    I will call my dealer today.
    Out of curiousity. Where did you find the information? It looks like a web-screenshot
    /Peter
  • 08-30-2007 6:46 AM In reply to
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    Hej Peter!
    You can only use old BL3500. Since a year or so they only have masterlink inputs. If you have a new one you will need a ML/MCL converter.
  • 08-31-2007 4:07 AM In reply to
    • pgerell
    • Not Ranked
    • Stockholm
    • Posts 77
    Hej Daniel,
    I didn't know that. Fortunatelly my BL3500 is quite old. (Mid 90's)
     /Peter
  • 08-31-2007 4:18 AM In reply to
    If you have an LCS9000 or any Beolab 3500 prior to the introduction of Beolink Wireless 1, then it would have a Masterlink socket AND a Master Link Control socket. You can see a full overview in the FAQ on the subject HERE
    Regards Keith....
  • 08-22-2008 7:19 AM In reply to
    • skd
    • Not Ranked
    • Joined on 06-07-2008
    • Posts 25
    never mind
