Latest post 07-31-2008 3:48 AM by joeyboygolf. 5 replies.
Page 1 of 1 (6 items)
  • 08-29-2007 12:19 AM
    TX 2 Turntable - tone arm
    I purchased a TX 2 in magnificent condition which just happened to have a mint MMC1 cartridge! However, when I push the play button the tone arm stops short of the record and platter and my precious MMC 1 lands  on the deck.  I'm afraid to monkey with the train which carris the tone - How can I correct this. Bill
  • 08-29-2007 2:39 AM In reply to
    Re: TX 2 Turntable - tone arm
    Hi Bill,
    This situation can be corrected with a simple adjustment. It is fully explained, with a drawing, in the service manual which can be downloaded from this site.
    http://www.beoworld.org/download.asp?file=BG8500-9000-9500-TX2_service-eng.pdf
    The only tool required is an ordinary screwdriver.
    Regards Graham
  • 09-03-2007 4:53 PM In reply to
    Graham: Thanks for advice - For some reason, my computer won't download the manual - do I have to convert the download to another system?
  • 09-03-2007 5:33 PM In reply to
    It's a pdf file so you will need Acrobat reader to view it.
    Regards Graham
  • 07-30-2008 6:37 PM In reply to
    Graham: Somehow I lost your answer as to how to repair my TX2'  myreply to you is a bit outdated, but if you can find the time to give me another word or two I would appreciate it..Thank you..Bill
  • 07-31-2008 3:48 AM In reply to
    You need to download the manual from the main Beoworld website. It will download as a .pdf file and if you have Acrobat reader installed on your computer it should open automatically.
    Regards Graham
