1st March February 2012
Latest post 12-03-2008 5:44 AM by Jandyt. 15 replies.
08-28-2007 4:49 PM
kwillers
- Joined on 08-13-2007
- Posts 17
Is it possible to upgrade the Beocom MKI (via sw?) so I can use the new style Beoline PTSN which allows 8 handset to be connected ? I have reached the 6 handset limit imposed on the old style Beoline
Marching On Together
Keith Saunders
- Joined on 04-16-2007
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
Which Beocom are you talking about ? Assuming you are talking about the Beocom 6000 then this requires a board change to make it a Mark II and is covered in several other threads like this one HERE I can assist you with such an upgrade if that is the route you wish to take. The Beocom 2 can have just a software update. You can also have more than one PTSN base if you wish.
kwillers
- Posts 17
Hi Keith thanks for the reply Sorry my post was a little vague I have both 6000's and 2's the 6000 are MKII already so they are sorted it s the 2's that are MKI. Is the Software update something thats a quick job or do the phones need to be sent away ? As for two PSTN bases, I assume that they CAN'T be linked together i.e share one phonebook, allow INT calls, and transfers from phones registered to one base to another phone on the other base.
kwillers
- Posts 17
Hi Keith Not sure I undersatnd the last point Are you saying the common phone book is only available for numbers entered from handset number 1. I'm sure I have entered numbers from other handsets and they are available to all hansets registered to the base. Or are you implying that its possible to register a handets with more than one base. I may just be being stupid here, sorry
Keith Saunders
- Posts 3,810
I think you mis-understood me, so I will restate to be clear on this point. You can enter numbers into the address book from any phone connected to the same base, so if you only have one base, it is simple, you enter you phone number and it is seen on any other phone. You can register a handset to up to four (4) bases then you must consider my previous last sentence statement. The handset number 1 issue only becomes important if - You have more than one PSTN base AND
- you are registering one or more phones to more than one base
If the above is NOT the case then forget the sentence you did not understand.
kwillers
- Posts 17
Keith Now I understand, if I use two PSTN bases I should have the same handset registered as handset number 1 on both bases then always add numbers to the phone book from the number 1 handset and they will be available to all handsets on all bases. I think that might be my prefered solution, ie two PTSN's (i already have a spare - long story) then I can have up to 12 phones - more than enough Kev
k984942
- Joined on 11-10-2008
- London, UK
- Posts 194
Hi all I have a MK1 6000 with s/w version 2.1. Are there any benefits of upgrading to 2.5, and if so, can I do this at home since (I believe) its just a software update? Also, what is the number displayed under the country code and software version? Thanks
32" RF VCR Avant, 2 x 28" VCR Avant, DVD1, Beocom 6000, Beo5, A9 Keyring!
Keith Saunders
- Posts 3,810
Generally speaking you do not need to upgrade the software unless you have a problem which needs to be fixed. Only minor issues are resolved after version 2.1 and certainly nothing which would warranty a software upgrade. To perform a software upgrade to any Beocom 6000 and Beoline product requires:- - A Service Jig for that product, see pictures below
- A B&O Software Service Tool
- An adapter cable
Software updates cannot be done without the above items. Below is a picture of a Beocom 6000 Service Jig The country code shown for UK software load is 044 which is the international code for the UK and the software version you already know.
k984942
- London, UK
- Posts 194
Thanks again Keith My 6000 is working fine so as the old adage goes, if it ain't broke...... As for the numbers, I understand the country code and software version, its the long number beneath these two details that I was interested in. Perhaps it tells you how many days or hours the phone has been used for?
k984942
- London, UK
- Posts 194
Nope. Just to be clear the display shows: 044-2.10 0004100929 I understand the 044 = UK 2.10 = Software Version Its the 0004100929 that I don't understand Thanks
Page 1 of 1 (16 items)
