Latest post 08-28-2007 5:42 PM by joeyboygolf. 11 replies.
Page 1 of 1 (12 items)
  • 08-27-2007 4:07 PM
    Help - Beo4 lost row of pixels
    My Beo4 lost row of pixels right in the middle.
    Is there a way of fixing this?
    Thank you!
    David the BeoPerson
  • 08-27-2007 4:11 PM In reply to
    Re: Help - Beo4 lost row of pixels
    Seems to be a common fault - I've had two of mine repaired, even though out of warranty,my dealer arranged these free of charge.  Just replaced the screens.
  • 08-27-2007 4:59 PM In reply to
    The only way is to replace the screen. The kit costs around £20 in the UK
    Regards Graham
  • 08-28-2007 8:15 AM In reply to
    Thank you for all replies!
    David the BeoPerson
  • 08-28-2007 12:46 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    joeyboygolf:
    Are they easy to replace?
    CraigSmile
  • 08-28-2007 1:10 PM In reply to
    Relatively! Requires a bit of patience and few tools. Instructions are provided.
    Regards Graham
  • 08-28-2007 2:32 PM In reply to
    • Jandyt
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    If you do one Craig, don't touch the little zebra contact with your fingers, use tweezers.
    Andy T.
    Poor me, never win owt!
  • 08-28-2007 3:10 PM In reply to
    • Craig
    • Posts 4,855
    Graham and Andy, thanks for the replies.
    CraigSmile
  • 08-28-2007 4:01 PM In reply to
    Where can I get the instruction?
    Also I have BeoLink 5000 with exact same problem.
    Assume it also requires screen replacement - any idea if part is still available?
    Thanks!
    David the BeoPerson
  • 08-28-2007 5:01 PM In reply to
    The kit includes basic instructions for fitting,
    The display on th 5000 cannot easily be replaced so best to live with it. This has always been the problem with the BL5000 and why their second hand value is so poor. Most have pixels missing and their is no cure as far as I know.
    Regards Graham
  • 08-28-2007 5:34 PM In reply to
    Note:
    1 out of 4, the PCB has the fault... (beo4)
  • 08-28-2007 5:42 PM In reply to
    The Stig - ver. 1.3:
    Note:
    Not in my experience. So far, every one has been fixed by the new display. Maybe I've just been lucky!
    Regards Graham
