Latest post 08-27-2007 8:46 AM by Christian. 5 replies.
Page 1 of 1 (6 items)
  • 08-27-2007 7:29 AM
    • ssm
    • Not Ranked
    • Joined on 08-27-2007
    • Posts 2
    Problems programming my Beosystem 7000
    Can anyone please tell me - is it possible to program my beosystem 7000 with a BL 1000 or BEO4. I destroyed my Beolink 5000 and cant delete an old time program (starting up my radio every morning at 6:30 winter time - a bit annoying in summer times....)
  • 08-27-2007 7:33 AM In reply to
    • henrik
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Stockholm, Sweden
    • Posts 299
    Re: Problems programming my Beosystem 7000
    Unfortunately, this is not possible. What you can do is to temporarily de-activate the timer - se this thread for more information: http://forum.beoworld.org/forums/thread/41427.aspx
  • 08-27-2007 7:35 AM In reply to
    • Christian
    • Top 100 Contributor
    • Copenhagen, Denmark
    • Posts 626
    You cannot change any timing without the remote used when the program was set up.
    Best solution: buy or borrow a BL5000. I do not think a BL7000 or MCP6500 will delete a timer set by a BL5000.
    Next best: preset volumen to 0. You do this by lowering the volumen to zero, and press SOUND STORE on your BL 1000.
    Best regards,
    Christian
    Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
    Addicted? Oh no.... ;)
  • 08-27-2007 7:53 AM In reply to
    • ssm
    • Not Ranked
    • Posts 2
    thx :)
  • 08-27-2007 8:35 AM In reply to
    • henrik
    • Stockholm, Sweden
    • Posts 299
    Christian:
    That depends on the software version of the Beolink - timers programmed with the latest bl7000 software can for example be changed with a last-revision bl5000 but not with a mcp6500.
  • 08-27-2007 8:46 AM In reply to
    • Christian
    • Posts 626
    Thanks for correcting that! Smile
