Latest post 08-28-2007 2:54 PM by Jandyt. 4 replies.
Page 1 of 1 (5 items)
  • 08-25-2007 1:19 AM
    • coho
    • Not Ranked
    • Joined on 08-25-2007
    • Posts 3
    Beogram 5500 Speaker Hum - HELP!!!
    I have a Beogram 5500 turntable and have purchased the 5 pin to RCA adapter cable so I can connect it to my Yamaha AV reciever I am having to run it through a phono preamp because my reciever does not have a phono input. Anyways, I am getting a speaker hum that is noticable between tracks and it increases with the volume. I have the ground wire connected to my reciever chassis but the pesky speaker hum remains. I have tried everything I can think of and was really hoping someone has had a similar experience and could share any advice for me .
     Thanks in advance........Coho in Alaska
  • 08-25-2007 5:33 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Beogram 5500 Speaker Hum - HELP!!!
    Hi Coho and welcome to Beoworld.Smile
    It sounds most likely that your beogram isn't earthed (grounded) via the adaptor cable. Simply run a earth/ground wire from the turntable chassis or the shielding on the Din plug to your receiver.
    Chris.
  • 08-25-2007 3:56 PM In reply to
    • coho
    • Not Ranked
    • Posts 3
    Thanks for the fast response Chris,
     I have a ground wire connected directly from the turntable chassis to the reciever chassis but still get the same hum. I can hear minor "crackling" when I first attached the wire, does that mean it is a good or bad ground connection?
     Any other ideas will be appreciated. This is frustrating.
    Coho
  • 08-26-2007 10:03 PM In reply to
    • coho
    • Not Ranked
    • Posts 3
    I finally figured out. What a numbskull I am. I was using a screw on the turntable that turned out not to be a good ground. After testing continuity with my meter I discovered the problem. All is well now and my beogram sounds incredible.
    Thanks for the help Chris!!
     Coho in Alaska.
  • 08-28-2007 2:54 PM In reply to
    • Jandyt
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    So glad you got it sorted CohoBig Smile
    Nice to have someone from Alaska on here, I bet you must be the only one!
    Andy T.
    Poor me, never win owt!
