I have a couple of questions about my newly aquired 610 k. First and foremost, I love the styling. Very modern, even still!
I read in a previous thread that you can stick a ribbon antenna with bannana plugs into the red input on the back. What is a ribbon antenna? Is it the kind that are plastic coated wire that separates into two sections, and usually has spade connections?
The radio also has another antenna input of sorts that is the same shape as the red one, but it is black. I am thinking that it is for the short wave reception. So...what should I put into that? I would like to play around with the shortwave channels sometimes.
One more question for now. When I am listening to an FM station and I push the stereo button up front...I can not get any stations on the FM. What is the "stereo" button for?
Thank you for any input my sage advisors!
Guy
