Latest post 08-23-2007 6:17 AM by Hiort. 2 replies.
Page 1 of 1 (3 items)
  • 08-23-2007 4:30 AM
    Beocom 2 and Beocom 6000
    Guys I need some help
    I currently have 3 Beocom 2's (MKI) connected to the older style PTSN base on the ground floor of the house. Everything works fine.
    Now I want to add some 6000 to 3 of the bedrooms on the first floor making a total of 6 handsets. I know thats possible but I'm concerned as I plan to pick up the 6000 via ebay or other sources as to which versions/models of the 6000 are compatiable with my system.
    Also am I right in thinking there is a base for the 6000 which can handle 8 handsets. If so can I link my MKI beocom 2's to this instead of the current PTSN base ? Would it be compatable. You see where I'm going here that would give me all 4 bedrooms on the first floor covered.
    I have read the FAQ and think I'm okay but I'm still not sure, and want to confirm before blowing a few hundred on an incompatable system.
    Yes I know I could add another 3 Beocom 2's but in my view the 6000 is better phone to use and where they are not 'on display' quite as much make a better chioce (the 2 is just so stylish but that dam keypad !!!). I can also pick them up a whole lot cheaper than the 2's
    Finally what about the Beocom 1 is that an option as I gather that a 6000 in disguise !!
    Thanks in advance
    Marching On Together
  • 08-23-2007 4:51 AM In reply to
    • matheyl
    • Top 500 Contributor
    • Joined on 04-18-2007
    • French Alps
    • Posts 228
    Re: Becom 2 and Beocom 6000
    Right,
    Beocom 2 is perfect as long as you don't use it..............
    I display mine more as a piece of art than a phone....
    Cheers, Laurent.
    Avant 28 DVD, BC2, 2300, BL2500, 8000, to name a few...
  • 08-23-2007 6:17 AM In reply to
    You cannot connect MkI Beocom 2:s to the new station (that handle 8 handsets). They are not compatible.
    Straighten that issue out with my dealer recently.
    /Claes
    _____________
    Happy owner of: BV10, 2 x Beocom 2, Beocom 6000, Beocenter 2, Beolab 3, Beolab 2000, Beo4, Beolab 11
    1:st prize winner Beoworld January Price Draw.
