Hello All - new member here!
I have a rather old but still excellent B & O MX TV, and have just purchased a new Panasonic DVD recorder to replace the old VHS.
I was able to work the old VHS machine using cannel 6 (we have only arial input) but cannot remember how this was set up, but on trying to set up the new recorder I can get nothing on the B & O AV but can get sound only using the V Tape.
I have tried the new recorder on other TVs and it works perfectly both sound and vision, and I have tried two different scart leads and made sure they are properly fitted.
I would be most grateful for your guidance.
Thank you.
