Latest post 08-21-2007 2:19 PM by Jandyt. 4 replies.
Page 1 of 1 (5 items)
  • 08-21-2007 10:19 AM
    • Kokomo
    • Top 100 Contributor
    • Joined on 08-21-2007
    • Spain
    • Posts 618
    LC 2 on/off function
    Please help!
    I have 4 LC2s and cannot disable the on/off function on any of them. I must be doing something wrong but I can't understand what.
    I follow the following procedure as stated in the instruction booklet via my Beo4:-
    Press LIGHT then LIST to display SETUP. Press 0, the LIST to display STORE. Press GO, Then 1.
    But it doesn't work!
    I've tried the above procedure with the lights on and off, but it makes no difference.
    As I live in Spain and powercuts are not uncommon, it means that if one has occured whilst I am out, when I return all the lights are on.
    Any advice much appreciated.
  • 08-21-2007 10:33 AM In reply to
    • maclife
    • Not Ranked
    • Joined on 05-16-2007
    • Brussels, Belgium
    • Posts 26
    Re: LC 2 on/off function
    kokomo:
    Please help!
    You have to continuously touch the half-dome (the sensi-touch field) of the LC2 during that process, otherwise your commands will be ignored. HTH
  • 08-21-2007 11:16 AM In reply to
    • Kokomo
    • Spain
    • Posts 618
    Thanks a lot, just tried it and it works!
    Why don't the instructions mention that small point?
    Thanks again - much appreciated.
  • 08-21-2007 11:48 AM In reply to
    • maclife
    • Not Ranked
    • Brussels, Belgium
    • Posts 26
    kokomo:
    Well, it’s mentioned on page 20 in the english version of the manual ("The three types of reprogramming are all carried out by holding the dark front half-dome (the sensi-touch field) and simulateously pressing the sequences of keys on your Beolink Terminal") but hidden so efficient that many people (including me) just didn’t find it when first trying ...
  • 08-21-2007 2:19 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Party!!!Big SmileParty!!!
    Just 14 minutes from question asked to problem solved!!
    That's what we like to see.Yes -  thumbs up
    Wonder how long it would have taken on the official site?Erm
    Andy T.
    Poor me, never win owt!
