Latest post 09-28-2007 3:35 PM by solderon29. 7 replies.
Page 1 of 1 (8 items)
  • 08-20-2007 5:35 PM
    7802 No sound . .. Help!
    hello
    my aged but wonderful 7802 tv has stopped talking - no sound! picture is still great but something somewhere has given up.,.. is this an easy and cheap fix?!
    thankyou
    mark
  • 08-25-2007 5:03 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: 7802 No sound . .. Help!
    Welcome to BeoWorld !!
    If you find the problem with the 7802, could you see if i can simulate it on my wife? LaughingLaughing
    As for the problem though (seriously) - you should ask either Dillen (moderator) or Neil (beovisions) for starters.
    Lee
    Smile
  • 08-26-2007 1:16 PM In reply to
    • Dillen
    • Copenhagen / Denmark
    • Posts 5,008
    Neil would probably be your best shot and I'm sure he can pull a rabbit or two.
    I generally don't do TV's or videos and don't even have the manual for the 7802.
    Nice TV though, a classic piece !
  • 08-31-2007 1:02 PM In reply to
    Given what you say, are you sure you have not pressed the "stereo" button which is marked "SOUND" on the top left above the left speaker ? If you have it will mute the sound, just press it again.
    Regards Keith....
  • 09-19-2007 5:17 PM In reply to
    hi guys and thankyou for the advice but no joy - had already tried the stereo button. It stopped very suddenly - worked one day but not the next, if that sheds any light?
    humbly,
    mark
  • 09-22-2007 12:38 PM In reply to
    Another favourite with this set is after you've been using your i.pod etc headphones via 6.5mm adaptor,you remove the headphones,but leave the adaptor still in the socket.This cuts out the speakers of course!
    If not the above,do you get sound via peripheral devices eg,vcr,sat etc?connected to the av sockets?
    You may have a problem with the supply to the amplifier stage,or the muting circuit with mutes the switch on noises etc.
    These sets are pretty much "bombproof",so I would'nt expect the problem to be major.
    Where abouts are you?
  • 09-24-2007 5:02 PM In reply to
    hi again
    yup tried those I'm afraid - no sound and all correct buttons pressed! I'm near Selby , N Yorks, could be a simple soldering job inside it but that'd be way beyond my simple skills!!
    regards,
    mark
  • 09-28-2007 3:35 PM In reply to
    A few quick checks with a meter would track this down I think.I can't believe it's anything serious,but you will need an Engineer's help.You' are some distance from me (Midlands)but you must have someone more local?Have you tried the Dealer List?
    Nick
