Latest post 08-21-2007 10:36 PM by Dave. 2 replies.
Page 1 of 1 (3 items)
  • 08-20-2007 2:30 AM
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    Is it ok to use an HD STB with a Beovision 3?
    I am just wondering if it is alright to use a high definition set top box with a Beovision 3, or will the resolution be too high for the screen, resulting in a grainy picture? Thanks for any advice on this! Smile
  • 08-20-2007 5:31 PM In reply to
    Re: Is it ok to use an HD STB with a Beovision 3?
    No problem! all HD stb I've seen has a normal RGB scart. but don't know haw good they are at downscaling a HD signal.
  • 08-21-2007 10:36 PM In reply to
    • Dave
    • Posts 2,328
    Thanks, yes that's the question, will it still produce a perfect picture in HD. The reason i want HDTV on a BV3 is because i still want to enjoy the 5.1 sound during HD broadcasts when we get more Beolabs, without the HD display hoo-haa (something that is thankfully irrelevant with CRT).
