Latest post 08-21-2007 1:55 PM by Craig. 2 replies.
Page 1 of 1 (3 items)
  • 08-19-2007 6:27 PM
    • waxer
    • Not Ranked
    • Joined on 08-19-2007
    • Posts 6
    BeoLink PC2
    Hi, can anyone tell me if this will work using Itunes as the music library and transmit onto my BC 9500? also, do you know the range?  cheers
  • 08-20-2007 11:57 AM In reply to
    Re: BeoLink PC2
    No, it is not supported.
    The supported Hifi all have a Masterlink connection.
    I highly recommend airport express for you.
    p.
  • 08-21-2007 1:55 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: BeoLink PC2
    wtlc2zpx:
    p.
       Also it only works with BS2, BS4, BS3000, BS3200 and some BS9000's.
    CraigSmile
