Latest post 08-21-2007 3:28 AM by ridax. 6 replies.
Page 1 of 1 (7 items)
  • 08-19-2007 2:06 PM
    Beolink 7000
    Hi Graham, Peter, Keith and other BnO guru's....I just bought a Beolink 7000 on Ebay today. I'll be needing some parts for it. Is there places I can get the parts and repair myslef or do I need to have the shop do it???
    I need the "nose" piece and LCD light, and i'd like to switch out the mirror and glass for new ...
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=320147297020&ssPageName=STRK:MEWA:IT&ih=011
    THanks, Keith
  • 08-19-2007 2:22 PM In reply to
    Re: Beolink 7000
    I believe that parts are still available from B&O so suggest that you contact your dealer.
    Regards Graham
  • 08-19-2007 3:11 PM In reply to
    • Fil
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Posts 90
    Re: Beolink 7000
    i recently had a new battery pack and aluminium plate replaced at my local dealer.................£138.00!..ouch....but well worth it!!
  • 08-19-2007 11:46 PM In reply to
    Re: Beolink 7000
    Frank Rizzo,
    Try getting in touch with Atlantic Systems - they are on the east coast. Very knowledgable people and know B&O very well.
    I have dealt with Paul I believe. Give them a call explain what you need. They will be able to give tell exact parts you need to replace and will be able to ship them to you.
    I have fixed one of my BL7000 with their help.
    Congrats with good deal on this remote. I was watching it as well  Wink
    David the BeoPerson
  • 08-20-2007 1:43 AM In reply to
    • PL212
    • Top 200 Contributor
    • Joined on 02-14-2007
    • Moderator - Seattle
    • Posts 318
    Re: Beolink 7000
    It looks like parts of the black paint have separated from the front glass as well, so you might need to budget for either a replacement front screen or do some touch-up work behind the glass with a paintbrush.
  • 08-20-2007 3:24 AM In reply to
    Re: Beolink 7000
    Great to hear that parts still are available!
    Is it possible to upgrade a non-RDS version to RDS?
    /Ola
  • 08-21-2007 3:28 AM In reply to
    • ridax
    • Not Ranked
    • Joined on 04-16-2007
    • Posts 44
    Re: Beolink 7000
    joeyboygolf:
    Others have told me that most parts are NOT available anymore, but I have not checked myself for quite some time, so only know from others that have tried to get parts (and as you know, it could just be a lazy repair shop that say parts are not available).
