Latest post 08-31-2007 3:10 AM by Puncher. 12 replies.
Page 1 of 1 (13 items)
  • 08-19-2007 6:19 AM
    • Top 75 Contributor
    • Joined on 04-01-2007
    • UK
    • Posts 970
    Want to play keyboard + Mac
    I have always wanted to play keyboard but never have. I have a Mac and saw how cheap these are
    Now I have no excuse. Can anybody guide me before I dive in.
  • 08-19-2007 1:18 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: Want to play keyboard + Mac
    They're great, I've got something very similar, and they are quick and easy.
    However, for learning keys, a weighted keyboard will be better. 'Keyboards' (with non-weighted keys) tend to be more difficult to get decent dynamics, and everything will end up being really loud and angular. A proper keyboard (with weighted keys) like a piano, will allow you to play much better, and much more sensitively.
    You'll also want a sustain pedal (incredibly cheap), and assuming you've got GarageBand, you're ready to go Big Smile
     Weekly top artists:
  • 08-19-2007 2:46 PM In reply to
    • UK
    • Posts 970
    Thanks, I do have Garageband. Where would you recommend I start. Any good books.
  • 08-20-2007 5:09 AM In reply to
    I do have exactly the same keyboard and use it together with Garageband. It's just great!
  • 08-20-2007 7:26 AM In reply to
    • Alex
    • Posts 2,990
    One of these Link would be suitable for your needs (there's a smaller option available, but I'd recommend the large one, more notes to play with Big Smile), and this. Just connect directly to the Mac via USB, and it'll work straight away with GarageBand. You'll probably also want some decent speakers connected to your Mac, unless you've got one of the newer iMacs, in which the speakers are pretty acceptable...
     Weekly top artists:
  • 08-20-2007 1:28 PM In reply to
    • UK
    • Posts 970
    Thanks for your help guys.
    To be continued...
  • 08-29-2007 9:46 AM In reply to
    • Sal
    • Top 200 Contributor
    • Joined on 04-30-2007
    • Indianapolis, USA
    • Posts 261
    If you want to move toward more of a Mac integration into music creation... I would take a look at the KORG Kontrol 49 + Propellerheads Reason.
    I have a G5 running Reason and it is a wonderful complement to the Korg MIDI keyboard / interface.
    Again, together the keyboard and software are about a $600 (max) investment, but well worth the creative power which is at your fingertips.
    -Sal
    Love B&O, but no longer addicted.
  • 08-29-2007 4:35 PM In reply to
    • Alex
    • Posts 2,990
    Reason is fantastic, although I'm not sure it's what the OP wants at all. GarageBand will be much more suited IMO.
     Weekly top artists:
  • 08-29-2007 4:50 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    What's an OP?
    Are you suggesting that Richard (the Avatar fiddler) is an old person?
    Poor me, never win owt!
  • 08-30-2007 2:03 PM In reply to
    • UK
    • Posts 970
    LaughingLaughingLaughing
  • 08-30-2007 7:04 PM In reply to
    • Jandyt
    • Posts 13,004
    Dalg uoy denioj Dlrowoeb eht yad erofeb em, ti stius uoy Drahcir!
    Ydna T.
  • 08-31-2007 2:49 AM In reply to
    • UK
    • Posts 970
    [:'(] loof lirpA dlo yllis eht em sekaM
  • 08-31-2007 3:10 AM In reply to
    • Puncher
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    I'm not sure weighted keys is a necessity if you do not intend playing real acoustic piano. A good keyboard action which is velocity sensitve and has aftertouch would be more than OK - IMHO. Very few common synths or electronic keyboards have real weighted actions, usually only specific "master" keyboards, specific electronic pianos and top of the range workstations etc., the vast majority of 5 octave keyboards and professional synths do not. Weighted keyboards will also be more expensive (and heavier).
    I would however get at least a 5 octave model rather than the 4 octave version you show in the pic if you envisage playing with both hands (while smiling to your right, Bobby Crush styleBig Smile)
