Latest post 09-28-2007 2:54 PM by Frank Rizzo. 13 replies.
Page 1 of 1 (14 items)
  • 08-17-2007 7:39 PM
    Passive Kit OVERRIDE
    I've got 3 passive kits now for my system.....and the 1 i've got for the home gym (i've got a TV in the GYM too)....
    So i'll Masterlink the Passive with the Downstairs Master system.....BUT
    WHat if I ran in an INPUT to the Powerlink too.......would 1 override the other.... I'm wanting to get TV shound thru the Passive when I want and then Masterlink sound when I want....any ideas???
    THanks, K
  • 08-17-2007 7:47 PM In reply to
    Re: Passive Kit OVERRIDE
    By using AV + TV it will play the sound from your master TV then you just have to set it to the same channel as your link TV.
    The Power link connection will not work as long as it connected to Maser link
    Is this to any help ?
  • 08-17-2007 8:19 PM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    Hi Frank,
    There is a way to do exactly what you want to do...but you need 2 more things, a BeoLink Active and the PC input adaptor.
    Stay with me for just one moment....  Connect the MasterLink, and the 'eye' to the Active kit, use the PC Input adaptor to connect RCA(Phono cables) frpom the TV to the PC input on the Active kit, use a FULLY wired Powerlink to connect the PL output on the Active Kit to tthe PL socket on the Passive kit, add "PC' to your Beo4 remote, and you're done!!
    Russ
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 08-17-2007 9:14 PM In reply to
    Yep Russ, that does it....now i just need the Ebay gods to look down on me....jajajajajaa
     The PC imput allows complete flexibility...and I really don't need to Waste a Passive Amp...correct??  I could just adapt the Powerlink outs on the Active to RCA's and use any cheaper AMP with RCA's as inputs....
     Active Kits with PC adaptors give the most flexability (similar to MCL 2 AV) yes??
    Thanks, K
  • 08-17-2007 9:35 PM In reply to
    Hi again....
    How do I add PC to the BEO4 remote???  Is it software...or just some buttons to push???  The remote is in Cali, Colombia....not the hotspot of technology.....jajajaajjaa.a
     THanks,
  • 08-18-2007 3:30 AM In reply to
    • beoaus
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Melbourne, Australia
    • Posts 445
    Presumably i could use this with the active and a Samsung TV audio output? Thus having the sound direct from the telly.
    Anyone have a picture and part number of the PC input adapter?
    Great tip..
    Beoaus.
  • 08-20-2007 9:20 AM In reply to
    • stefan
    • Top 50 Contributor
    • 200 miles from Struer
    • Posts 1,733
    <>Is there really a PC input (Audio in) on the Beolink Active ? Could not find it in the user/reference manual...
    <>Thanks
    <>Stefan
  • 08-22-2007 11:13 PM In reply to
    Hi Russ,
    Thanks here for sure...how do I "add PC" to my remote????
    THanks, Keith
  • 08-23-2007 9:20 AM In reply to
  • 08-23-2007 12:10 PM In reply to
    • Russ
    • Posts 641
    Hi Frank,
    On the Beo4 press 'List' and 'Stand By' at the same time the display will say 'Add?' press 'Go', look for 'PC' on the list of options, press 'Go', the Beo4 will say 'Added'.  You're ready to use.
    Russ
    McLean, VA USA
  • 08-23-2007 12:39 PM In reply to
    Thanks a ton Russ.!!!
    Once I do that, How do I switch between the PC input source and the Masterlink Input source??
    Additonally, where do I get a PC adaptor for the PC port on the Active Kit????
    Thanks again Russ......K
  • 08-23-2007 1:00 PM In reply to
    • Russ
    • Posts 641
    You switch inputs just like you always do on a Beo4, press the button (or use 'list' and 'go') for the input you want.  The PC Iput Adaptor uses a nonstandard B&O part number in the US, as it is locallay sourced.  Check with your local shop.
    Russ
    McLean, VA USA
  • 08-24-2007 12:47 AM In reply to
    • beoaus
    • Posts 445
    Is this the part number 6270316?
  • 09-28-2007 2:54 PM In reply to
    Hi RussR....Thanks for your help so far...I'm doing this right now...is that correct part number...6270316 ???????????   Is that a standard DIN to RCA???
    THanks,
    Keith
