Latest post 08-18-2007 3:26 AM by patpinnock. 6 replies.
Page 1 of 1 (7 items)
  • 08-17-2007 4:35 AM
    BeoCenter 9000
    Hi all you helpful B & O fans.
    I am really new at this and have just joined.  You may have been asked this a million times before, but I cant find the answer on your forum.
    I have and ancient Beocentre 9000 (serial No 04363709) which I bought new in 1987 - yes 20 years ago and it is still performing beautifully right through the house with the BeoLink system. I have recently been gifted an Ipod Nano and have transferred all my CD's to it.
    The question is, can I connect Ipod to Beocentre and if so how?
    Hope you can help
    Pat Pinnock
    Filed under: ,
  • 08-17-2007 4:44 AM In reply to
    • van
    • Top 100 Contributor
    • Joined on 10-19-2006
    • Brighton, UK
    • Posts 663
    • Gold Member
    Re: BeoCenter 9000
    Hi and welcome to BeoWorld Pat,
    I'm not sure if this would be at all helpful to you:
    http://home.swipnet.se/ridax/ipod.htm
    All the best
    V
  • 08-17-2007 5:04 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: BeoCenter 9000
    Ridax's solution would allow you to control the iPod with the B&O remote. It would connect to either the AUX input connection, or to the TAPE 2, so Van's suggestion would give the best results in the end. If you don't know anything about wiring electronics for yourself, then you can order them pre-made (they're normally a vaguely DIY solution).
    Of course, you can do it without Ridax's little controller, a much simpler option (from the point of setting up) is a direct cable with no extra fuss.
    Connect iPod directly (click me)
    And your Beocentre is not old by any means! A lot of our members regularly use systems dating as old as 40-50 years. Big Smile
     Weekly top artists:
  • 08-17-2007 5:05 AM In reply to
    • Mico
    • Top 500 Contributor
    • Joined on 05-06-2007
    • Finland
    • Posts 136
    Re: BeoCenter 9000
    The Ridax Ipod dock was my solution in similar situation (my BC9000 is from 1988). The Ipod dock connected to Tape 2 and is remote controlled by the BL1000 (or any other B&O rc).
    In family we have one dock and five Ipods, the biggest debate is whose Ipod gets the honour to serve as the source.
  • 08-17-2007 6:04 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Re: BeoCenter 9000
    http://www.ibundo.de/en/index.html
    might be worth examining...
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 08-17-2007 11:32 AM In reply to
    Re: BeoCenter 9000
    Oh how I miss my BeoCenter 9000...  Erm
    David the BeoPerson
  • 08-18-2007 3:26 AM In reply to
    Re: BeoCenter 9000
    Thanks for all your help!
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
