Latest post 08-20-2007 2:03 PM by Hagen2000. 9 replies.
Page 1 of 1 (10 items)
  • 08-16-2007 6:38 PM
    Beocom 6000 battery change
    Does anyone know the "code" that you need to enter after a battery change on a BC 6000 handset?
    /Ola
  • 08-17-2007 3:57 AM In reply to
    Re: Beocom 6000 battery change
    I assume you are talking about "Pin Code". Well you should not need a pin code, but if you are being asked for one it almost certainly means that you have got 6 handsets already registered and you did not de-register the handset before you changed the battery.
    I guess you have a Mark I Beocom 6000 handset, please confirm ?
    Regards Keith....
  • 08-17-2007 6:27 AM In reply to
    • dp
    • Not Ranked
    • Joined on 06-28-2007
    • Posts 47
    9#9#9*655 then go (middle button) - that should work ;)
  • 08-17-2007 10:08 AM In reply to
    I do have the MK 1 and as I can remember you should dail a "code" so that the handset knows that you have changed battery pack.
    Is this the 9#9#9*655 ?
    /Ola
  • 08-17-2007 10:18 AM In reply to
    Why don't you download the user manual????????
    Regards Graham
  • 08-17-2007 12:02 PM In reply to
    If all you have done is change the battery, then it should work without entering anything. If it is asking for a Pin code then the problem is most likely what I previously described.
    Regards Keith....
  • 08-17-2007 2:56 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Do you know, I have often wondered about this.
    In the manual it says "If replacing with a NEW battery, follow the instructions supplied with the battery"
    In the instructions in the new battery it says to do the 9#9# thingy. However, the new battery comes in a discharged state and thus the 'phone can't be switched on.
    So, how the flippin' heck can you enter 9#9#9 etc?
    Graham, downloading the manual will be of no benefit to him as it just tells you to refer to the instructions in the battery!
    Keith, I'm quite sure he was not talking about the pin number but this silly 9#9# thing.
    Andy T.
    Poor me, never win owt!
  • 08-17-2007 6:02 PM In reply to
    Cor.rect Andy so it must have been the service manual I read it in. I just checked and it's not on the site so I must have downloaded a copy from the old site.
    The old site is of course no longer available and I've had two new hard discs in the computers since then!!!!
    Somewhere I have a print of it ..........
    Regards Graham
  • 08-20-2007 6:14 AM In reply to
    Thanks!
    I had lost my small note that came with the new battery and I couldn't find any thing in the user manual. (Of course I look there first, Graham!)
    Does anyone know what this code does? After entering the code, the handset sais "No battery"???
     /Ola
  • 08-20-2007 2:03 PM In reply to
    I think the handset is "learning" some parameters about the battery (e.g. average discharge time to display the correct loading level) and this code is used to reset these parameters.
    Hagen
