Latest post 08-20-2007 5:46 PM by The Stig - ver. 1.7. 7 replies.
Page 1 of 1 (8 items)
  • 08-16-2007 11:48 AM
    Beomedia 1
    Hi all,
    I have 1-2 questions about Beomedia 1 and its everyday use:
    1) When i use it for example to hear net radio, and then i want to browse the web,in order to see the main menu(n.music-n.radio-photos-web) the only way to do this is by pressing repeatedly LIST button, then PC appears again, and then GO. is there an easier way to go to main menu of beomedia 1?
    2) i have installed beolink passive throughout my house. When i hear net music and then open an i.r.  in a slave room,the music can be heard but the Beovision7-32 gets black(does not show anything)
    Sorry if this q's have been discussed again
    Hope you give me some hints.
    Thank you in advance,
    Dimitris
    -Dimitris
    Filed under:
  • 08-16-2007 12:24 PM In reply to
    • Alex
    • Top 500 Contributor
    • Joined on 04-16-2007
    • New York, NY
    • Posts 176
    Re: Beomedia 1
    1) Hit the "MENU" button on the Beo4 ;-)  ... sometimes the easiest questions have the simplest answers
    2) I tried replicating the problem in our showroom and I dont seem to be having it ... but all of our TVs here run off of BeoSystem 3 (including our BV7s!!!).  It might be a minor glitch that has since been resolved with a software update so I would check with your local dealer to see if they've heard of the problem and if there's a fix.
    Store Manager Bang & Olufsen Broadway 927 Broadway New York, NY 10010
  • 08-16-2007 4:21 PM In reply to
    Re: Beomedia 1
    I think it's because the beomedia change to link mode (S-vhs instead of VGA out) when you activate the link room, do you have the S-VHS cable connected?
    the menu button should work if not placed PC as the first thing in the list!
  • 08-19-2007 2:04 PM In reply to
    Re: Beomedia 1
    1)thank you both for your kind answers
    2)stupid me, i tried everything apart from the MENU button. Silly me!!
    3)No i dont have the S-VHS cable connected.What and where should that be placed? (obviously between BV7 and Beomedia but what is the point in that?)
    -Dimitris
  • 08-19-2007 3:26 PM In reply to
    Re: Beomedia 1
    because the system picks up the picture and sound off the scart and then it goes down masterlink and coax to link tvs
  • 08-20-2007 2:51 AM In reply to
    Re: Beomedia 1
    From the link room, do you call the N.MUSIC by typing N.MUSIC or PC?
    p.
  • 08-20-2007 5:37 PM In reply to
    Re: Beomedia 1
    wtlc2zpx:
    p.
    N.Music for sound only,PC for sound with Picture Smile
  • 08-20-2007 5:46 PM In reply to
    Re: Beomedia 1
    DrDimitris:
    If it's the case that Beomedia1 changes into link mode! it change the resolution to fit a normal tv screen via the S.vhs. it has to go to same AV as the sound RCA plugs, if you use AV4 you have to swap it to AV3 or use a composite cable instead..
