Latest post 08-16-2007 5:52 PM by Calvin. 8 replies.
Page 1 of 1 (9 items)
  • 08-16-2007 5:02 AM
    • pgerell
    • Not Ranked
    • Joined on 05-24-2007
    • Stockholm
    • Posts 77
    Using a beolab 3500 with a beosystem 5500
    I have two ML/MCL questions.
    Is it possible to create a link room setup with a beolab 3500 controlling a beosystem 5500 in another room?
    How about a MX7000?
    Thanks,
     Peter
  • 08-16-2007 5:44 AM In reply to
    Re: Using a beolab 3500 with a beosystem 5500
    Not sure how old your Beolab 3500 is, but you have a Masterlink socket and an Master Control Link Din socket. By default it will use the Masterlink, but this can be changed.
    This can be connected to your Beosystem 5500 in another room and the MX7000 also supports datalink.
    Regards Keith....
  • 08-16-2007 7:24 AM In reply to
    • pgerell
    • Not Ranked
    • Stockholm
    • Posts 77
    Thanks for the prompt reply,
    I do not know the age of the Beolab3500. I have been offered to by a used one.
    My house has a LexCom Home network with a Beo masterlink module in the basement.
    http://www.schneider-electric.se/Downloads/PDF/monteringsanvisningar/LXH_MasterLinkmoduleBO100-MLNEUTRAL98518_01.pdf
    My television has a converter to masterlink. Do you think it would work with a similar converter to the BS5500?
    Or maybe I can run MCL over the Lexcom masterlink module. I think it is passive unit. Like a conjunction box with RJ45 connectors.
    /Peter
  • 08-16-2007 7:51 AM In reply to
    OK, if you have Masterlink, then no problem using the Beolab 3500
    Have a look at my FAQ HERE on the Beolab 3500
    Regards Keith....
  • 08-16-2007 8:21 AM In reply to
    • pgerell
    • Not Ranked
    • Stockholm
    • Posts 77
    Thank You,
    Do you know if the converter I need for the Beosystem 5500 is the same as the one I have for my MX7000?
    One being used as a linkroom speaker, while the other is to be used as the master of the system.
    /Peter
  • 08-16-2007 8:44 AM In reply to
    Most likely, what is the Type number of the one you have ? is it 1611 ?
    Regards Keith....
  • 08-16-2007 5:13 PM In reply to
    • pgerell
    • Not Ranked
    • Stockholm
    • Posts 77
    No, it is a 1615.
  • 08-16-2007 5:46 PM In reply to
    To used the lexcom system you will need a beolink converter to the BS5500
    If you have a Power link modul in the lexcom system, then i think that can be used to MCL, but think ML is better.
  • 08-16-2007 5:52 PM In reply to
    • Calvin
    • Top 500 Contributor
    • Joined on 04-16-2007
    • London
    • Posts 233
    I looked at this same setup 2 or 4 years ago. My memory is that that it was far cheaper to spend the money getting a good quality additional set of passive speakers, low resistance/reactance cable, and a (rarish and expensive) sensor to hook up to the 5500
