Latest post 08-19-2007 1:52 AM by Daniel Seiler. 10 replies.
Page 1 of 1 (11 items)
  • 08-14-2007 8:19 AM
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    How do i get the latest firmware updates for Beosound 2?!
    I've tried to figure out how to install the latest firmware on the BS2 vis our intel imac and it just isn't happening! Do i need certain software, or can it only be done via a PC??
  • 08-14-2007 2:52 PM In reply to
    Re: How do i get the latest firmware updates for Beosound 2?!
    You can download the latest software which updates the firmware from the B&O site HERE
    All BeoSound 2s can be updated to be Mac compatibility, however it is not possible to use a Mac to do the first update on an older BeoSound 2.
    So, if you have an older BeoSound 2 you must update the BeoSound 2 via a PC. After this first update, all future updates can be done via a Mac.
    Regards Keith....
  • 08-14-2007 11:42 PM In reply to
    • Dave
    • Posts 2,328
    I've raked through all of the downloads on the B&O site and the problem is, how do i get the firmware updates actually onto the BS2, has anyone actually done it? I've tried everything on the mac, and have already used a PC to do the first upgrade. I'm so confused as to why the firmware doesn't work. I even downloaded the technical software (firmware reader) but it did not work on the mac. I think B&O have forgotten about mac users! Sad
  • 08-15-2007 2:10 AM In reply to
    The program you download from the B&O site contains the fireware and this program is installed on your PC or MAC depending on which one you have downloaded. The following is what is stated on the B&O web site
    Here you can download the newest drivers and BeoSound 2 firmware for PC, or get the latest iTunes plugin for Mac.
    MAC users only:
    Please note that if your BeoSound 2 was purchased together with a software version previous to 2.00, you will need to update the BeoSound 2 firmware using the BeoSound 2 version 2.00 installation for PC.
    » Version history - BeoSound 2 firmware
    » Download BeoSound 2 firmware for PC (2,8 Mb exe file)
    » Download BeoSound 2 firmware for Mac OS 9 (0,8 Mb sit file)
    » Download BeoSound 2 firmware for Mac OS X (0,8 Mb sit file)
    I tried by downloading the PC version to my Windows PC and it installed fine. Can you do that successfully ?
    Regards Keith....
  • 08-15-2007 2:11 AM In reply to
    I did provide a reply, but it is currently awaiting moderator approval
    Regards Keith....
  • 08-15-2007 4:19 AM In reply to
    Actually i do not have a BS2 myself. But doesn't the update function work together with iTunes? So that you have to use iTunes for FW Updates. There should be a button for this somwhere on the bottom left or right.
  • 08-15-2007 8:19 AM In reply to
    • Dave
    • Posts 2,328
    I have an intel iMac, B&O never created software and firmware that was compatible with intel macs. Grrr, a real shame.
  • 08-15-2007 8:39 AM In reply to
    Yes you are right. I also have Intel Macs, and i just downloaded the BS2 Plugin for iTunes that B&O provides, just to find out about your issue. But this does not even run, it crashes already on startup. Really a shame, and Intel Macs are not that new anymore, they are out quite some time, so enough time for B&O to adapt their software.
  • 08-16-2007 5:46 AM In reply to
    Have a look at the post I did yesterday below which has just been released from the moderators area
    Regards Keith....
  • 08-16-2007 5:55 AM In reply to
    • Dave
    • Posts 2,328
    Well i think the old firmware worked when i did it via PC, but no avail for the latest MAC updates. This is the site i was using to try and figure it out. It just ain't happenin'! *sigh*
    The iMac just won't accept these files. Sure it downloads them ok, but they are completely useless. Grrr
  • 08-19-2007 1:52 AM In reply to
    Must be the problem that those files/software is just not Universal, so not running on any Intel Mac. Too bad.
