Keith
In answer to your questions:
i) The BV7 and BV6 are in different rooms. They are linked with a ML cable and a coax cable {via RF amplifier}.
ii) A beosystem 2300 is in the same room as the BV7. This is also connected to the BV7 via an ML cable and separate ML box
iii) I meant to say that I have been unable to re-establish any sign of a masterlink connection. The physical connection between the two TV's I assume is uninterrupted - though the cables are run through walls. The two TV's are normally linked. For instance by selecting DTV, DVD or CD on the BV6 I can then play the sky box, DVD or BS2300 respectively even though located in the BV7 room. When however the link has failed only the TV button seems to work for the BV6 (giving analogue TV via the coax connection) and all other functions have no effect. On the other hand if I go into the other room where the BV7 is located DTV, DVD and CD are available via that TV.
iv) Both the BV7 and BV6 were set up by the local B&O engineer and normally default to the ML connection being active. I therefore normally don't have to do anything other than make sure both TV's are plugged in at the power socket and that the security PIN's have been keyed in for each.
Thanks for any help you can give.
Regards
Ken
