1st March February 2012
Latest post 04-23-2010 11:34 AM by burantek. 14 replies.
08-12-2007 1:40 PM
brendon
- Joined on 04-18-2007
- Posts 54
Hey
I need some help. I am attaching a ML\MCL converter
bow to me Avant to play some to my passive Jamo speakers. How every I
can not get any sound. Are there some installation instructions some
where that might tell me how to set this up? Am I missing something
here is my current setup: Avant Powerlink cable to ML\MCL box Avant Masterlink cable to ML\MCL box Passive Speaker to ML\MCL box Thanks
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
Do you need the Masterlink cable connected? If you are just using it as an amp to drive some speakers I would imagine you only need Powerlink. This was all the older MCL2P had. Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
Craig
- Posts 4,855
Have you downloaded the user manual. It is on the site I have just checked. Craig
brendon
- Posts 54
Where is the manual? I did not see it maybe I looked at the wrong thing. I saw the MaterLink handbook and the MLC2 guide.
I used the the Powelink cable that came with me BeoLab 2. Would that work?
Craig
- Posts 4,855
Try this link Brendon LINK Craig
Christian
- Joined on 04-16-2007
- Copenhagen, Denmark
- Posts 626
Yes it will turn green, when the amp. is on. Maybe the PowerLink socket in the Avant is dead (or turned off if you can do that).
Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
Addicted? Oh no.... ;)
Jonathan
- Joined on 05-03-2007
- Melbourne, Australia
- Posts 1,164
I have an Avant with a surround kit and was thinking of using my ML/MCL as an amp to run passive speakers through the tv. I understand everything said before me, but which connection do I plug in the cable? There are front left & right speaker connections and rear left and right speaker connections on the back of the TV. The Converter is left and right channel, so if I plug it in to (for example) the left front speaker connection, will I have stereo sound coming out of my speakers? If I connect a second ML/MCL Converter to just one of the rear speaker connectors will I then have surround sound? Hopefully my questions make sense, and it would be great if someone could help...... Thanks everyone
My B&O: 2009 Catalogue and Pricelist
Christian
- Posts 626
PowerLink carries both left and right signal. So it does not matter whether you plug it in the left or the right front PowerLink socket. And yes, if you have another MCL/ML and another pair of speakers, and you use the rear PowerLink socket you will have surround sound.
burantek
- Joined on 05-04-2007
- SE USA
- Posts 6,214
Reviving an old one here...
@jldmelb: Did you end up doing this? Results?
I am considering doing the same thing.
Page 1 of 1 (15 items)
