Latest post 08-12-2007 12:28 PM by sajpratty. 7 replies.
Page 1 of 1 (8 items)
  • 08-12-2007 10:15 AM
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Beomaster 1000 FM aerial connection
    Is it still possible to get an FM aerial to fit a BM1000? It has a large Red connection for the aerial. My BM900 has the same type.
    CraigSmile
  • 08-12-2007 11:15 AM In reply to
    Re: Beomaster 1000 FM aerial connection
    Hi Craig,
    I use a pair of banana plugs and a ribbon-type antenna. Works well enough.
    It would be so nice looking to have a telescopic antenna rising from the back though - I searched Maplins, CPC and Farnell for a plug so I could make up my own but to no avail.
    Cheers,
    Steve
  • 08-12-2007 11:24 AM In reply to
    • Craig
    • Posts 4,855
    Thanks Steve, that would be fine as where I have it I would not be able to extend a telescopic one anyway.
    CraigSmile
  • 08-12-2007 11:32 AM In reply to
    • Jandyt
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Hi Craig.
    The two Beomaster 1000s I got last week for £3.20 have both been adapted.
    One has some coax sticking out of the grill and the other has a coax plug fitted (badly) like the ones on the back of a telly.
    They both sound wonderfulYes -  thumbs up
    Andy T.
    Poor me, never win owt!
  • 08-12-2007 11:56 AM In reply to
    • Craig
    • Posts 4,855
    Just got some Banana plugs from Ebay. £2.75 inc P&P. Somewhere I have a ribbon aerial, just need to find it.Laughing
    CraigSmile
  • 08-12-2007 12:15 PM In reply to
    Way to go Smile
    If it's doing a good job of hiding (like my stuff does!) ordinary twin-core cable will do if you split the ends by the right length, approx a yard.
    Steve
  • 08-12-2007 12:20 PM In reply to
    • Craig
    • Posts 4,855
    Well at the moment I have an old screwdriver stuck in the connection. Seems to be working though.
    CraigSmile
  • 08-12-2007 12:28 PM In reply to
    jandyt:
    Hi Craig.
    Andy T.
    Oh wow - result! I remember seeing them and toyed with the idea of getting them but chickened out when I read they had been modded. Glad they turned out okay for you.
    Steve
